Reply To: Why we use ambient occlussion node here instead of incerting a value node directly to subtract color 2?
Forum Archive Why we use ambient occlussion node here instead of incerting a value node directly to subtract color 2? Reply To: Why we use ambient occlussion node here instead of incerting a value node directly to subtract color 2?
#73932
elijah0429
    Hi Spikey, thanks for the image. May I know what are the 4 lines referring to? I would guess the left side is input, right side is output? Why the 0.9 would change to 0.8 tho on the second picture? Also, if I am not taking it wrong, the third map range means that all the input that is lower than 0.9 will have an output to 0. So does the green line mean any linear relationships or are they simply arrows?
