Forum Archive › Why the Snapping movement as I Scale X axis on the Bezier Circle › Reply To: Why the Snapping movement as I Scale X axis on the Bezier Circle
Yes the curve is infinitely thin, there is no scaling like that. In this case the curve is just a guiding object, but if you wanted to give the curve some thickness, you can use the extrude parameter:
