Hey there, so far I haven’t run into that issue and can’t duplicate it. Could you double check that they are all in the same group that is being used? Click on Use Count and see if all the meshes show up in the list. Also be sure that Whole Group is turned off so that they are emitted individually.
Hope that helps!
