Forum Archive › Why does the “Density” setting for texture controled hair growth only work with “Children Hairs” in Blender 2.90? › Reply To: Why does the “Density” setting for texture controled hair growth only work with “Children Hairs” in Blender 2.90?
So, now I’ve found at least partially out, why Blender uses the “Density Setting” for an “Image Texture” only if there’re “Child Hairs” activated:
1) If I paint and assign the “Hair Density Texture” before combing or otherwise manipulating the hair in the “Particle Edit Mode” the hairs will grow with “Density” checked in the “Influence Settings” of the texture only in areas that aren’t 100% black. No “Child Hairs” are needed! This view is the same in “Object Mode”, “Texture Paint Mode” and in “Particle Edit Mode”
a) “Texture Paint Mode
b) “Particle Edit Mode” before starting editing
c) “Particle Edit Mode” after combing
d) It looks the same after switching back to “Object Mode” . Here a view in “Object Mode” recreated later the same way as demonstrated above:
2) If I comb or edit the hairs before assigning a “Hair Density Texture”, then I need to activate “Child Hairs” in order to make this texture affect the hairs if I check “Density” in the texture’s “Influence Settings”. As soon as I do the first brush stroke in “Particle Edit Mode”, the hairs get kind of baken, a “Delete Edit” button for freeing that bake appears directly under the mode selection buttons “Emitter” and “Hair” in the “Particle Properties Tab” of the “Properties Editor”:
a) “Particle Edit Mode”
The “Particle System Settings” are greyed out since the “Particle Simulation” has hander over the control of the hairs to the manual editing in “Particle Edit Mode”.
b) Creation of the “Hair Density Texture” in “Texture Paint Mode” with the combed hair visible
c) The same view in “Object Mode” without “Child Hairs”
d) The same view in “Object Mode” with “Child Hairs” (Interpolated)
e) Switching back to “Particle Edit Mode” makes all hairs visible, even those which are hidden through the “Density Influence Setting” of the “Hair Density Texture” in case of the use of “Child Hairs”:
SUMMARY:
1) Assigning a “Hair Density Texture” before editing the hairs in “Particle Edit Mode” makes the hairs only grow in areas that aren’t 100% black. Therefore the view of the hairs is the same in “Object Mode”, “Texture Paint Mode” AND in “Particle Edit Mode”.
2) Assigning a “Hair Density Texture” after editing the hairs in “Particle Edit Mode” doesn’t influence the hair growth. The hairs grow everywhere, where the settings in the “Particle Properties Tab” of the “Properties Editor” allowed them to grow. The view in “Particle Edit Mode” shows all hairs” whereas the view in “Object Mode” hides those hairs that have grown in 100% black areas of the “Hair Density Texture”. This masking is only working with “Child Hairs” turned on.
The hair interpolation for “Child Hairs” takes all hairs into account, even those hairs hidden by a “Hair Density Texture” that has been assigned after manipulating the hairs in “Particle Edit Mode”. This explains why I had a feather hanging at the beak of Piero even after removing the hairs on the beak (even those inside the beak and the throat!) . This feather was an “Interpolated Child Feather”:
1) “Object Mode”
2) Same view in “Particle Edit Mode”:
Conclusion: If I had assigned the “Hair Density Texture” to Piero before combing the hairs, I wouldn’t have needed any “Child Hairs” and would have simply set the “Hair Number” higher which would have given me a predictable behaviour of the hairs whereas “Interpolated Child Hairs” proved to be problematic.
