Forum Archive › When I use the node editor, in cycles render view, the object isn't affected in 3Dview, even if I turn into rendered mode…. › Reply To: When I use the node editor, in cycles render view, the object isn't affected in 3Dview, even if I turn into rendered mode….
I find the solution, thanks, when i create a new material, i forgot to delete the oldest so I could’nt displaying the results on 3DVIEW.
