Reply To: When i select the inner circle of the vault im suppose to click (P) then separate selection instead of doing what its suppose to it makes this red box. WHAT DO I DO TO FIX THAT???
Forum Archive When i select the inner circle of the vault im suppose to click (P) then separate selection instead of doing what its suppose to it makes this red box. WHAT DO I DO TO FIX THAT??? Reply To: When i select the inner circle of the vault im suppose to click (P) then separate selection instead of doing what its suppose to it makes this red box. WHAT DO I DO TO FIX THAT???
#25599
Jonathan Lampel
    Looks like it did indeed separate by selection, so I’m guessing somehow the bounding box display is turned on? You can turn it off in the object properties under display.
