Reply To: When i plug a shader in mix over another shader allready plugged it it does not move it down to the next input of the mix shader like the video does it just disconnects it
Forum Archive When i plug a shader in mix over another shader allready plugged it it does not move it down to the next input of the mix shader like the video does it just disconnects it Reply To: When i plug a shader in mix over another shader allready plugged it it does not move it down to the next input of the mix shader like the video does it just disconnects it
#80720
    Yeah by default it’s better if it swaps like before, the move was if you wanted a disconnect then you hold ALT. That behavior should be in reverse.
