Reply To: When I do the Bevel Weight to fix the shading issues it doesn’t work.
Forum Archive When I do the Bevel Weight to fix the shading issues it doesn’t work. Reply To: When I do the Bevel Weight to fix the shading issues it doesn’t work.
#72028
    Maybe your sides aren’t completely flat.
    Exaggerated:
    Select the side Faces and S, X, 0 (with Pivot Point set to Median Point), or enable the LoopTools Addon and use Flatten.
    Maybe that helps.
