Forum Archive › When I do “Select sharp edges” it appears that almost 100% of my edges are selected, which can’t be right. Any tips? › Reply To: When I do “Select sharp edges” it appears that almost 100% of my edges are selected, which can’t be right. Any tips?
Check that, I figured it out. If you are in vertex mode it selects all the vertices on the sharp edges, which then highlights all the edges, even if they technically weren’t intended. Using edge mode solves the problem.
