Reply To: What if it doesnt show up on right even if it is enabled in 4.2
Forum Archive What if it doesnt show up on right even if it is enabled in 4.2 Reply To: What if it doesnt show up on right even if it is enabled in 4.2
#90892
    Hi Samantha @Starksc27 ,
    If you are talking about our beloved Suzanne,
    the Eyes are part of the Suzanne Object. To Select the eyes, you need to go into Edit Mode and Select them there. For instance: P > Separate > By Loose Parts:
    Then switch back to Object Mode.
    There are other ways, like hover over an Eye (in Edit Mode) and press L to Select the Eye and everything that’s connected to it…
