Reply To: VonnBott Properties – can’t find? Which menu is it on? The script executed find (or it appeared to)
Forum Archive VonnBott Properties – can’t find? Which menu is it on? The script executed find (or it appeared to) Reply To: VonnBott Properties – can’t find? Which menu is it on? The script executed find (or it appeared to)
#27097
Wayne Dixon
    Ok so you have linked in the character so make sure you create a proxy and select the actual rig (not the mesh)
    This will make a local copy of the armature, and the ui will show
