Reply To: Vertex is not connecting with New Edge/Face from Vertex (F)
Forum Archive Vertex is not connecting with New Edge/Face from Vertex (F) Reply To: Vertex is not connecting with New Edge/Face from Vertex (F)
#73265
    Hi, you have a few, so-called double Vertices, like you can see here (I pulled them apart, just so that you can see it better):
    Solution: First Select that misbehaving Face (easiest in Face Select Mode) and Delete it.
    Then select All with A and then M > Merge by Distance.
    Now you can Fiil with F.
