Forum Archive › UV / Normal map problem ??? › Reply To: UV / Normal map problem ???
Ok, I haven’t used UV0 vs. UV1 in Sketchfab, but it sounds like there are two separate UV layouts. To check, go to the UV Maps section of the object data properties and delete any layout that’s not the main one:
