Reply To: Unwrapping a cube and baking an Image Texture is not working as expected
Forum Archive Unwrapping a cube and baking an Image Texture is not working as expected Reply To: Unwrapping a cube and baking an Image Texture is not working as expected
#84453
    You have two UV maps and you’re using the wrong one that is just one big UV face, change to the UV map that has the correct unwrap. The one that ends with .001 is the correct one, the camera icon should be set to On in that one.
