Forum Archive › Translucent Transmission Problem. › Reply To: Translucent Transmission Problem.
Hi Jeff,
You should probably reduce the Roughness of your Transmissive Material (to almost 0) and maybe even set its Color closer to white (if reducing the Roughness isn’t enough).
