Forum Archive › To make the cut off corners on the first one, is there a more efficient way ? I used the knife tool and cut a triangle and then disolved the faces individually. › Reply To: To make the cut off corners on the first one, is there a more efficient way ? I used the knife tool and cut a triangle and then disolved the faces individually.
Select the vertices of the corners, press CTRL +B to access the Bevel tool. Press V for Vertex only mode.
