here is a better pic of the inside panel if this helps, I did try to fix the one side more but I am a little confused on the best way to straighten it out, I am not sure how it happened either but I did need to go back to a earlier save or two from previous screw ups. Also would the best way to fill in the shape again is to select the vertices all the way around and hit f or would the plane be flat to the device doing it that way? At least I think my buttons are good now. And for pics in the future I guess I should leave my question first and then pics below.
