Reply To: Time node?
Forum Archive Time node? Reply To: Time node?
#77831
    Hi Toby @Cap3d ,
    In the Shader Editor, you can (for instance) use an Input > Value Node and set the Value to: #frame. If you wanna go fancy and impress your friends, you can name the Node (Label)  Time:
    and in Geometry Nodes, you can simply search for time, to find the Node.
