Reply To: The video will explain my problem
Forum Archive The video will explain my problem Reply To: The video will explain my problem
#98951
Charles
    I’m not sure you need to start over here but the advice is solid. Keep the blend file as a v1 and start a new v2. In time you’ll realise that the time you spend trying to correct the mistakes you made early on will take longer and produce a less satisfying result than just starting again and getting the key foundational pieces in place from the outset
