Reply To: THE SHIFT + Brush to smooth is too strong
Forum Archive THE SHIFT + Brush to smooth is too strong Reply To: THE SHIFT + Brush to smooth is too strong
#80362
    Well,
    You can disable the Cursor display in one of the Brushes, before using the Annotate Tool:
    Un-check that and then press D, will probably be the fastest…
    Or write a small Python script that disables the Cursor, when switching to the Annotate Tool and enables it again when you switch back…
