Reply To: The PBR Shader tutorial was very good and I liked that it was related to Substance Painter. Two questions: 1. In th…
Forum Archive The PBR Shader tutorial was very good and I liked that it was related to Substance Painter. Two questions: 1. In th… Reply To: The PBR Shader tutorial was very good and I liked that it was related to Substance Painter. Two questions: 1. In th…
#24731
Jonathan Lampel
    The textures are packed into the .blend file, so you can find them in the UV image editor or by searching within an image texture node.
    As for AO, I typically mix my material with a black diffuse shader and use the AO map as the mix factor. Hope that helps!
    Apologies for not seeing this until now, thankfully we have a new system in place to make sure questions don’t go unanswered in the future.
