Forum Archive › The faces around the outer circle are light gray, the faces that I made by extruding vertices around the bites are a much darker gray. Why two colors? › Reply To: The faces around the outer circle are light gray, the faces that I made by extruding vertices around the bites are a much darker gray. Why two colors?
Light gray = normal is facing outward. Dark gray = normal is flipped.
