Reply To: Texture turns pink after adding the mix node to the bump node
Forum Archive Texture turns pink after adding the mix node to the bump node Reply To: Texture turns pink after adding the mix node to the bump node
#75399
    I have a 4 GB GPU and it renders fine..I even Mixed in another Shader without a problem:
    Maybe it’s time to update your Graphics Card driver. Remember that Eevee is completely dependent on your GPU!
