Reply To: Texture turns pink after adding the mix node to the bump node
Forum Archive Texture turns pink after adding the mix node to the bump node Reply To: Texture turns pink after adding the mix node to the bump node
#75395
    That is weird, that has never happened tome ever, even with a crappy computer. I believe yes, this might be another case where the blend file could be useful to do the troubleshooting.
