Reply To: Texture problem when voxelizing
Forum Archive Texture problem when voxelizing Reply To: Texture problem when voxelizing
#79500
    I used exactly 180° and 90°, but Iäm not sure if that’s correct (I expect it, but…) I don’t know what is causing that rotation in the first place…
    Let’s try this: ALT+R and then Voxelize:
    Maybe you should also look at the Scale? (Try removing the minus signs, or just use ALT+S, whatever gives the best result…if it makes a difference at all)
