@smurfmier1985 Everything I mentioned is standard within the Unity editor. As far as installing Unity you can do it using either the Unity Hub or installing Unity directly based off a specific version. I personally use the Hub as I like having multiple versions of Unity, usually an alpha version and a stable build. I believe you’re using the alpha version based off your screen shots so it will be a bit different.
