Reply To: Stuck with shading issues on curved surface
Forum Archive Stuck with shading issues on curved surface Reply To: Stuck with shading issues on curved surface
#34104
Jonathan Lampel
    Hey @killzone , are you referring to where the highlights get narrower around the holes? That’s happening because there are two edges very close together in that area, and edges that are very far apart in between where it gets wider.
    Try continuing your edge loops all the way along the gun instead, like so:
    It’s less ideal since it adds more geometry, but it should fix the shading.
