@duerer the terminology in the Map Range Node is not great; you can basically ignore the Min and Max and read: From A … to … and From B … to …
The Min and Max aren’t even minimum and maximum values when you don’t have Clamp checked; it extrapolates outside the interval. And even with Clamp enabled, Min can be larger or smaller than Max.
