Reply To: Spikey’s Math Lab
Forum Archive Spikey’s Math Lab Reply To: Spikey’s Math Lab
#64353
    Chapter 1:4 – Value Control, takeaways:
    – When you are controlling values and you  see the gradient in a flat plane moving left and right, you’d think that’s the only thing that is happening, but actually values are causing a shift in the Z axis as well. The handy value graph is a great tool to visualize the height information.
    – The operation Add and Subtract shifts the values up and down.
    – The operation Divide and Multiple scale the values.
    – There’s some talk about linear interpolation along the gradient that I don’t quite get. It seems to be something about the gradient just going from left to right.
    – The Power operation introduces curvatures and bending.
    – The color ramp node is great for remapping a gradient, but even better is the map range node.
    – Remapping the values linearly? I don’t get that. But I think it has to do with how Spikey has been throwing a straight line in the Cartesian plane sometimes when showing some math.
    – The efficiency of the node tree is something to keep in mind since it can bog down a scene with too heavy computation.
