Good call, thanks for pointing that out! Indeed I should have explicitly mentioned it in the tutorial: so the key is to duplicate your initial object before applying any boolean operation and either hide it or move it to another layer. You can also parent the source object to the one you’re modifying so that they always keep the same position if you plan to move things around.
/Thibaut.
