Forum Archive › [SOLVED]Tail Double Rotation not working as intended › Reply To: [SOLVED]Tail Double Rotation not working as intended
I wonder if your deformation bone’s axis is opposite of the control bone. That could explain why inverting it would be a solution. You can turn on bone axes visibility in the Armature data properties under display.
