Forum Archive › [SOLVED]Tail Double Rotation not working as intended › Reply To: [SOLVED]Tail Double Rotation not working as intended
@dbchesties I believe you want to “roll” the bone with CTRL + R in armature edit mode. You can hit CTRL + R + 9+ 0 if you want to roll it 90 degrees specifically, and so on.
