Reply To: Solidify causing artifacts
Forum Archive Solidify causing artifacts Reply To: Solidify causing artifacts
#84871
    Hi Zoltan,
    You can reduce the shading artefacts, but switching to Complex and maybe Add some more Edge Loops:
    But better results are to be had, by Shrinkwrapping the Mesh to a higher resolution ‘helper’ Mesh, that has the same shape, but without the holes.
