Sounds like your origin was off the surface of your rivet. Sometimes snapping works wonky, but there are always ways around it and it’s easy to have the wrong options turned on. When you’re in a bind, you can always ask us and we’ll do our best to help out. Try posting screenshots or videos so it’s easier to troubleshoot. That said, I admire when someone is auto-sufficient enough to grind trough a problem and solve it, I always say Grit is a super power worth acquiring. Good job on finding a way out of your predicament Daemeon.
