Reply To: Smooth by angle modifier no affecting my Boolean holes
Forum Archive Smooth by angle modifier no affecting my Boolean holes Reply To: Smooth by angle modifier no affecting my Boolean holes
#93317
Shawn Hopkins
    Thank you, Omar and Martin, for your responses. According to the tutorial I am following, Johnathan said that we would normally do as you suggest, but because we’re using a smooth by angle after the Boolean modifier that is going to override the shading with those new settings, we should adjust it in the existing smooth by angle modifier in the object being cut. When I increase the angle, I have no success [on the video, this is working great for the instructor🙃]. I will try to add a modifier to my cutting object when I get back from work. Thanx again for the aid…
