Reply To: Shouldn’t the shadow catcher planes block the sunlight instead of letting it pass through?
Forum Archive Shouldn’t the shadow catcher planes block the sunlight instead of letting it pass through? Reply To: Shouldn’t the shadow catcher planes block the sunlight instead of letting it pass through?
#64632
    I have seen this, but I couldn’t figure out what is going on here. It’s not something obvious to me.
    The lighting seems different in the two examples. I don’t know where the light is coming from; a cube with a window cut  out, lit by an HDRI doesn’t give the result as in the second image.
    If you could provide your .blend file (with all textures packed!), I might have a better chance to figure out what is going on.
    Simply changing the room to a Shadow Catcher shouldn’t change the shadows.
