Reply To: Shift key will center the knife cut on both sides, is there way to center it only one side?
Forum Archive Shift key will center the knife cut on both sides, is there way to center it only one side? Reply To: Shift key will center the knife cut on both sides, is there way to center it only one side?
#87545
    …or simply make the cut backwards, holding SHIFT for cutting the first Edge and then releasing SHIFT for the second.
