Forum Archive › Shift key will center the knife cut on both sides, is there way to center it only one side? › Reply To: Shift key will center the knife cut on both sides, is there way to center it only one side?
The behavior as you mentioned goes back to before 2.80, so it’s probably a bug in 4.2.
