Forum Archive › Shift key will center the knife cut on both sides, is there way to center it only one side? › Reply To: Shift key will center the knife cut on both sides, is there way to center it only one side?
Oh, I think I found it…
You are using 4.1 (or before?) in 4.2 it behaves as I mentioned! (Mind you, that might be a bug…in either version)
