Reply To: Seven is the number of perfection
Forum Archive Seven is the number of perfection Reply To: Seven is the number of perfection
#60322
    @me1958424 not to me, I still see a spiral and not a circle with a center. Remember those numbered dots that you had to connect in order, to make a drawing of a palm tree, or…I must have made too many of them 😉
    Actually liked the one with the hexagons better.
    You asked about those infinite patterns that grow larger, now I thought of something; there exists something a p-adic numbers (where p is a prime).
    you could also use 10-adic numbers, although they are not commonly used.
    Where rational numbers can go infinitely to the right (after the decimal point), 10-adic (or decadic) numbers can go infinitely to the left.
    Look at this:
    the lines above the digits mean that that part repeats. The right ones are the decadic numbers and they also ‘rotate’ when you multiply 1/7 by an integer that is not a multiple of 7. And they even consist of the same digits as the decimal ones.
    But for something to be larger, there needs to be some kind of ordering and that is missing in this system, so not exactly what you were looking for, I guess.
    But when talking about circles and their center, I had to think about this, because in a p-adic circle, every point inside that circle is its center (mind-blowing, right?).
