@duerer, I was hesitating at first, but with the bathroom light entering right on top of this light, it reduces the translucency. If I crank up the light, then it gets out of balance again. The fact that both you and Adrian are not sure, means that I should have redirected the bathroom light somewhat more to the right, as it then removes the ambiguity (while keeping a clear path for light entering the opposite side of the room). It’ll be still a bit off for sure, but I guess my choices create confusion and that is something I need to be more aware of.
On that note, is there some kind of search engine that you know of for light setup and references based on an atmosphere, time of day,… you want to recreate? (with some more explanation)
