Reply To: Séb’s progress
Forum Archive Séb’s progress Reply To: Séb’s progress
#69115
Sébastien Lenaerts
    Chapter Lighting a bedroom with Blender; Trying to make the sunset while I’m brushing my teeth atmosphere.
    First I tried with a sunset image, but I felt the way the sun reflected on the clouds did not make any sense
    I put the same image as a world background and suddenly the angles seem more believable.  I’m not sure though if the sharpness of the shadows are correct.  Should it be more sharp or not.  In this image the bathroom light is too discrete.
    I’m not sure where the white/blue color on the window sides is coming from, given the color temp, I would expect it to be yellowish as well like the wall.
    Below I increased the bathroom light value a bit.  The bedlight seems a bit too shiny, but since it is in a corner where the sunlight doesn’t reach, maybe it is believable.   @jlampel,  What would you do different in these renders? I must admit, this is quite challenging as it seems you can be off by miles just by a tiny change.
