SO, the reason for this, is, that to blend between cells, a (probably White) Noise Texture is used to ‘mix’ between the two, which works great for images, to “blur’ the border, but when you have a border with a hieght difference like in A, it doesn’t give a result like B:
, but it picks either one or the other height (and maybe some in between, depending on how the Noise is used), thus producing those spikes and higher Subdivision only makes the spikes more and thinner.
