“The question is, do you really need it; the pattern repetition is only noticeable, when you look at it from far away, but then you wouldn’t need displacement and when you are close enough to need displacement, you wouldn’t need the Scattershot… (of course, when zooming in or out you’d need both, but not at the same time…).”
The faraway makes sense to me, and I’m guessing that when I am up close, since I am not trying to shift the original texture, the cell border problem doesn’t occur since I am using a different setup altogether.
This was incredibly informative! I realize I was trying to shoehorn the scattershot addon into something that doesn’t necessarily need it, especially when the tiling won’t be as noticeable. Thank you for your time again spikey!
