Reply To: Rotate a plane exactly parallel to the ground
Forum Archive Rotate a plane exactly parallel to the ground Reply To: Rotate a plane exactly parallel to the ground
#77747
    You’re actually better off creating a new plane and then giving the desired measurements. Most of the time when modeling, it’s easier and faster to start over than to fix what’s already broken.
