Reply To: Rotate a plane exactly parallel to the ground
Forum Archive Rotate a plane exactly parallel to the ground Reply To: Rotate a plane exactly parallel to the ground
#77749
Craig Wieland
    In the 3d viewer you could also just open the n panel and 0 out the location, and Rotation, but that would be the same as Alt+G and Alt+R. note this only works if you have not applied the location, and Rotation.
