Reply To: Rotate a plane exactly parallel to the ground
Forum Archive Rotate a plane exactly parallel to the ground Reply To: Rotate a plane exactly parallel to the ground
#77748
    I agree with Omar: often it is better to re-start. You need to suffer, so that you learn to never Apply the Rotation again (unless you really can’t avoid it)!
    But here’s a way to do it:
    The trick is to make a new Custom Orientation in Edit Mode and then enable ‘Affect Only Origins’ and Align to Transform Orientation:
    Don’t forget to un-check  ‘Origins’ when you’ve done this.
    Then, in Object Mode, you can simply Clear the Rotation with ALT+R.
