@waylow. – thanks for the response, I am still confused (surprise, surprise).
1. What is the slider supposed to be used for?
2. how do you flip between ik and fk, if you don’t bother with ik/fk snapping, I am guessing you just position the bones correctly?
3. you where right, there were values in the fk bones.
4. my understanding is the with fk, the leg follows the hip rotation unless I isolate it. If the hip rotation is off, then the leg position will also be wrong, which would be really obvious when the switch from ik to fk happens, (pretty sure the answer to this is yes) right? Hope this question makes sense, but I am still confused.
again thanks for the help, need to take a break, reaching my frustration level.
Thanks – T
