Reply To: Ring material turns into white disk after adding Noise Texture to planet material
Forum Archive Ring material turns into white disk after adding Noise Texture to planet material Reply To: Ring material turns into white disk after adding Noise Texture to planet material
#100734
    Hi Nuzran,
    The problem is not the Planet, but the fact that you have 2 Rings. Just disable (or Delete) the second one:
