Also sometimes you try to merge by distance, so you select everything with A, then M and merge by distance but nothing happens. Try checking that vertices are for sure on top of one another:
This happens to me sometimes, that I try to merge and the distance is not enough because the verts are not occupying the same space. Try checking for that as well, just in case.
